Formuler Z8 Failed to load vod
Beumas
I have a formuler Z8 and mytvonline2 works fine with live tv, but the VOD is getting an error that says Failed to load.
I have a cabled internet connection and fast internet so that’s not the problem. I have updated everything to the latest versions.
can anybody help me?
Reactions: Hectorious
1,039
2,010
Hi @Beumas
I had another user with same problem, he was using unsecured (old) portal url. Check your dashboard and use new secured portal url and the problem should be solved ?
13r0wn7
17
24
Mine does the exact same, the only way I can sometimes get it to work is disconnect the IPTV end then enable
Gigi
I tried this on my formuler Z8, didnt help. Now im using Formuler Z10 pro max and cant even find the app at the MArket. It used to work perfectly before 1 year ago but since then i need to restart device daily to be able to load VOD section. maybe thats exactly how it should work, i dont know. Appreciate all inputs
