Help please
Silky
Having issues with pixelating green salad whilst watching sport on fire cube can anyone please help
1,013
1,986
What app do you use on fire tv ?
And did you install latest version of your firmware ? Try to make an update on fire tv stick settings - my device - info - search update.
Beside any other IPTV app on your Android Fire TV device, it’s important to install the VLC player as well.
You’ll find the VLC player in the official Fire TV App Store.
The VLC Player brings the right codec which might help you to play all video formats smoothly, not only live TV, also most of the VOD content require it.
Just install the VLC App beside your main IPTV App to have a smooth video flow on Android, that’s it.
In case of any video content can’t be displayed in your main IPTV app: Just install the VLC player which is often the solution to display the video content cause it brings the right video codec.
