Help
Ian thack
Can someone please help
I downloaded siptv to my amazon fire stick
Had a trial 12hr period I then activated the app and added a new M3U url
But I can’t reset the siptv app it seems to be locked up with no access to any channels
Jan 7, 2019
168
82
droelfmalbumst
how do you mean reset siptv? you want to delete the existing test url?
If yes you have to do it over siptv.eu where you also added the m3u url
Ian thack
Hi thanks for your reply
I did this and added a new M3U url but the app just seems to be locked it will not connect to anything the app is showing some channels but when selected just says connecting then buffering then no connection
Removed app and reinstalled but it’s just the same
Kuben
115
142
25
Ask the support what they mean with reset. I think they just mean to go away from it and reopen it.
Ian thack
The reset is normally on the app when you first install it and add the trial M3U
The trouble is there dosn’t seem to be a support for the siptv app
Jan 7, 2019
168
82
droelfmalbumst
don't they mean to reset the line? delete the playlist and add it again?
reset the app just means to restart it but that won't change anything... or maybe they mean to "reload" the app?
So when you're in the app press "0" and the playlist gets reloaded...
