MAG 424W3 - Hidden Portal Access.
pmilo
Hi there all, I had bought a MAG Box 424 w3 and MAG 420 W1 by some supplier,
and I discover they had hidden in the Menu the Portals Access setup,
is any way can enable the portal access on the menu or check what hidden portals were used on this box before?
is any way can do this without Flash the firmware on the Box?
any advice will be much appreciated. many thanks
All the best
pmilo
is this will affect the BOX, ? just boot in recovery to view the Hidel Portal URL page? then boot as normal again?
many thanks for the update !!
casz
Did the factory reset work for you? I'm in the same situation where i need to update the portal url but can't access the portal as it's hidden
