Mag 424w3
stevemit
I picked up a Mag424w3 box... I SHOULD have known better given the last year plus that Informir would block the device as well as they did with the other boxes...But I didn't read and they will NOT take the box back.. Does ANYONE know of a NO_BLOCK firmware available yet for this box please? I would really appreciate any help. Thank you.
1,051
2,021
www.simpleiptv.net
not sure if its helpful for 424 but have a look here please:
stevemit
Thank you for the advice... There is not file there "yet" for the 423...The box is fairly brand new.. I appreciate your help!
stevemit
No Grigor...No solution yet... Have you ?
The only other thing to do is to switch to a Android box (425)... That does work...
Let me know if you find any solutions..I will as well if I do.
Grigor Stamboltsyan
The problem is with linux based MAG 424 and I still have no solution, just using STB emulator on Nvidia TV which is also Android and the portal works
Zeljko777
Work,work with orginal Ministra
Not with shit multiple panel XC,or other
Use Orginal,work Orginal
St Martins43
Can you tell me how to do it on a 425 as I am struggling with the same issue
lucaxxdb
Hi, news for Unlocked Firmware? I have the same issue "Firmware is outdated" when I try to use external portal. INSANE!!!!!
Zeljko777
yes you can use what you wannt afcourse
all this multiple Panel hawe backdoors,and many bug and you know it
that old story use normally stuff,but all that coast if you wannt use Profesionall
Mac69
Well I received my mag424w3 and pleased to say it is working fine . I checked with my provider first if he supported it .
I use a lot of movies on my flash drive and now find they all play perfect , some did not use to on my old mag250 , they must have improved the codecs .
AngelCMAG
What did you do to get it working fine? You seem to be the only one to figure out how to use the MAG 424 without a problem.
Mac69
As I said I just contacted my provider and he gave me a new portal address to type in .
And since then I have had two trials with other providers that also work .
arniesack
21
UK
@Zeljko777 I know this is an old thread, but I would be very interested to know how you work directly with Ministra on a MAG. Any tips?
