Mecool Kiii pro with IPTV
rog8811
#1
Hi peeps, I have spent today stripping out my old spiderbox setup and replacing it with the Mecool Kiii pro android box. First thing I wanted to try out was of course IPTV so, as I have used it already I downloaded smartiptv and got on to my supplier for a trial connection.
Well the app works.... to an extent.. none of the buttons that I am used to on a smart TV work on the android remote, no blue button action for instance to access groups. A long press of OK gets you to the first level of groups so that you can get to the correct country. but after that there is nothing to do but scroll through the channels which is a labour of love.
I will get back to you when I have tried perfect player.
rog8811
#2
Perfect player app tried and tested, it is well named, it took ages to load everything up but works very well with an air mouse once it has finished.
