Recording IPTV on Enigma device
SONY007
Using E-channelizer the stream type has been changed from IPTV to DVB which is what allows for the correct epg to load for each stream. The IPTV is working, but the only way it appears it can record is by using the timeshift options. The epg's for all IPTV streams are all available but selecting to record/timer via that option results on zero data being recorded. Is there a solutions to record and use the timer by using the EPG option? Device is a DM800se.
Reactions: arniesack
maragfct
90
I can record. But you can’t record if you are already on iptv channel. Zap to satellite channel and then add timer recording. And don’t play recorded video until recording finishes
maragfct
90
unfortunately I don't know work around this.
If I can record IPTV and watch another recorded video, that would be great
