Cuvillier
Active Member
Feb 19, 2016
327
351
France, FRA
cuvillier
aj3177
Check your download link m3u and check if it end with... &type=m3u_plus&output=mpegts
yes it does...
So with your file, just copy lines with sky uk with other channels you want... And past them to à New txt file and nemame this file to .m3u
ok, thanks.
and for grouping - like sports, movies, kids etc?
Also do I need to do this daily/weekly? I understand that the files are updated daily on the servers...
Cuvillier
Active Member
Feb 19, 2016
327
351
France, FRA
cuvillier
yes it does...
ok, thanks.
It's not necessary if you dont want to get update.
aj3177
ok, so without update it can work for 3 months or say a year?
How important are updates? Just want to understand if I should actually be spending time on channel sorting and grouping.
please guide me on the channel grouping process as well.
Thanks.
Cuvillier
Active Member
Feb 19, 2016
327
351
France, FRA
cuvillier
Thanks.
Yes, updates are just a edit on list.
Me i use link directly, so I don't know.
For example, I use this first line to make group about all Sky uk channels:
Code:
#EXTINF:-1 tvg-name="Sky UK" tvg-logo="" group-title="",SKY UK
http://clientportal.link:8080/live/username/password/0.ts
Then down this line put the sky uk lines channels..
Reactions: JJaypops
aj3177
Thanks.
Code:
ok, this helps.
If I want to do one step ahead by making another 'sub group' under SKY UK - eg Sports or Movies, how should I write it?
Are there any playlists software available to do this or is it manual for each file?
Cuvillier
Active Member
Feb 19, 2016
327
351
France, FRA
cuvillier
Thanks.
Code:
ok, this helps.
After, put this line :
Code:
#EXTINF:-1 tvg-name="Sports" tvg-logo="" group-title="",Sports
Now you see what you have to do.
aj3177
Code:
ok, this helps.
Code:
ok, understood. Its going to be a long process...
Thanks very much for your help.
Mohammed Najim
Actually i'm using Rapid IPTV with my Samsung 42 Inch TV and it's working perfectly but sometimes i'm facing this buffering issues and it stops for couple of seconds and return back again and it's really annoying sometimes.
Knowing that i'm using a very fast internet of 50MB/Sec Fiber Optic. Is there any solution for this ? do i have to open some ports or anything from my router ?
If you have another solution to make it works better without buffering please advise ,, Additionally on my computer it's working super great without any buffering issues.
Thanks, and waiting a positive massive feedback :)
IPTV Community
Administrator
Jun 3, 2015
537
1,651
214
iptv.community
Router config->Enabling "IGMP Snooping" and Disabling Firewall may help
Reactions: Jamietd
wwe
64
William Elders
hi
i have iptv now working on my Samsung smart tv but I have a long list 4000 + channels I don't want to edit any out at this stage but would like them to appear on my tv in folders
Ive tried everything and I can't find any help anywhere else
Cuvillier
Active Member
Feb 19, 2016
327
351
France, FRA
cuvillier
hi
Did you upload your playlist with m3u options ?
harryporter
184
45
harryportir
!. You have to use m3u_plus list in mpegts with options, smart iptv application from app store and blue button on the remote controll to have groups
Reactions: wwe
wwe
64
William Elders
Ok I think I did this but will try again I might post the last bit os the upload
wwe
64
William Elders
harryporter
184
45
harryportir
Are you shure that you are using this smart iptv app
and inserting the list on http://sip******* WARNING FRAUD **DON'T BUY** PLEASE REPORT TO ADMIN *******/mylist/ via tv`s mac address?
Remote Control commands
Tizen TVs (J/K series), Samsung H series
P+/P- and Arrows - switch pages, groups, channels and videos
UP, UPx2 - show current programme information
DOWN - show channel history
SELECT (OK), CH LIST - load channel list in play mode
INFO, INFOx2 - show current programme information
Number Keys - channel number selection; "0", PR CH - channel history
RETURN - hide channel list and infobar; Go back to primary list
EXIT - exit the application
P.SIZE, TOOLS - change stream/video aspect ratio
PLAY/PAUSE/STOP - play/pause/stop stream/video (exit video player)
PLAYx2 (quickly) - permanent infobar
PLAY_PAUSE - play/pause stream/video; show groups in channel menu
TTX/MIX - enable/disable 3D mode (Side-by-Side)
AD/SUBT - change subtitle track in stream/video (if available)
REC - toggle DVB input on/off
RED - settings in primary list; select audio/HLS track in stream/video
GREEN, GUIDE - EPG information; choose video play mode
YELLOW - show all channels; digital clock or aspect ratio in play mode (option in settings)
BLUE - show Groups; settings in play mode
wwe
64
William Elders
Yes smart iptv the same and script loaded loaded sip Tv as stated but when I press the blue button it's goes to setting
