Smarters Pro auth problems
nojretlas
I cannot get the app to work on the TV, works on Android with NO issues.
On the TV I get "Authorization Failed on above host"
I am out of ideas.
1,013
1,986
I am out of ideas.
as discussed in pm, try the things i told you and lets see if that is working then. if not, just reply to my pm please ;)
lesliejohn
Trying to set up my Samsung. Literally copied and pasted the info from my 3rd party reseller. Works on all my other devices, but will not work on my Samsung TV. I keep seeing this smarters.link, but no idea what this means
reseller name
Username (provided by reseller)
Password
Reseller link
What am I doing wrong?
vitshinzo
204
383
www.iptvluxury.com
vitshinzo
reseller name
Password
Reseller link
As I see you are newbie here
If you have valid rapid iptv subscription contact your seller
If you don't have rapid iptv service then contact your provider
1,013
1,986
reseller name
Password
Reseller link
IPTV smarters on Samsung tv need a different server url, your provider need to setup a unique url for that device and app, ask your provider or get a trial/subscription from us ;)
Fabio Sousa
Switzerland
Hello Guys,
I am also trying to set up smarters iptv app on my LG, but i have no more ideas... I used the m3u URL, then just username as PW with the generic url... Nothing works. How should I proceed, what is meant with using the above-mentioned url , should i use thaturl alone?
vitshinzo
204
383
www.iptvluxury.com
vitshinzo
Hello Guys,
If you have rapid subscription
Change url to
Fabio Sousa
Switzerland
OMG, so it works ^^ so easy -.- Thank you... Everything just tv guide is nonexistent and one can not sort the channels for example by name.
Faceoflife
All the problems of smarters pro is the server link, i'm using it since almost 2 years and it's working, the bad thing u cannot make many favorite
