Stalker Portal Player for Android TV
hensoft
#1
Why be limited by any other OS? Android OS is known for its ability to run Multiple Apps at the same time. The App Store concept makes it easier for the users to use the software without wandering throughout the internet.
Now you can use Stalker Portal 5.1 or lower with your Android TV device.
The best part: We offer you a personalized app! We set your company name and logo. Want different pictures of the design? No problem, it’s included in the deal!
Main Features:
  • Live streaming
  • Auto-Play
  • TV archive
  • EPG support
  • Video Club
  • Tariff plans
  • Categories
  • Radio
  • Multi-Audio
  • Multi-Subtitle
Mite1200
25
Austria
Reseller Username
MITE-IPTV
#4
These icons (again) look very cheap and unprofessional in my opinion. And the branding is way too much. The interface itself doesn't look modern in any way. The (newer) ministra portal looks way better. And this doesn't look like Stalker 5.1 at all somehow, I've tested it. It must be heavily modified if this really is Middleware 5.1. But have your opinion on it. :p
