Hi all. Apologies for this “How longs a piece of string” question but I have a Zoomtak T8Plus-2 Android set top box and am running (or attempting to) TiviMate 2.7.5. When I have input the Xtream codes address, user name and password and pressed the next button there is a short pause and I get the error “An error has occurred while processing the playlist. Make sure you have entered the correct data and check your internet connection”.
The internet connection is good as I am also running IPsmarters pro and XCIPTV player both installed and up and running first time with the Xtream codes information I have so I am confident the address etc has no errors, I have set up IPtv players several times now and appreciate the importance of good and accurate syntax.
I have ensured Tivimate has full access in permissions and to my knowledge I have no firewall operational on the router. Because there is a short pause before TiviMate spits out the error I think it is communicating with the server but not getting any further than that eg. downloading the playlist but that is a guess on my part. What is throwing me is that the other 2 operate flawlessly, in fact the entire sofware installed on the stb operates fine on the same connection.
I have had TiviMate up and running previously so I know it operates on the stb I have and I have run out of ideas now and it is driving me mad so any suggestions are welcomed.
TA
TA
