TVIP S412-415-605 is both Android and Linux box
Zoorg
#1
There is no obvious place for Linux boxes.
Or TVIP boxes in general.
Because they can use both Android and Linux
I have for example a TVIP S412 using Linux.
I think it works much better than Android
One yhing Im concerned about though, is the web browser.
Like, when using it, how do I get back to TV ?
The only thing I found that worked is reload portal.
Should be an easier way
