Xtreme Editor!
mario_70
#1
Hi, since i sterted to use Xtreme Editor to transfer epg to my Enigma box, i just realize that picture on every channel i change is pixelated for a few second. I didn't see that effect before when i was transfering a list stright to my box. Is anyone have the same?
Anthony henderson
103
40
Reseller Username
weescotsman
#2
I have zgemma h2s and runs smooth with xtream-editor, have you updated to the latest image on your box... out of the firmware i tried ipab is a fav of mine with good support from there fb page
mario_70
#3
Hi, I have dm920 UHD and so far i cannot find to many software to use on my box. I'm using stock one "opendreambox 2.5". I was checking on Dream Elite also and it was the same. I mean xtreme editor working pretty good, i can make changes of channels, grouping, add EPG and smoothly send to my box. But that pixeling after channel changing is strange. It just happening for a few second more or less on different channels. Before i didn't see that at all, but i was sending line stright to box. Maybe it's a box OS, but so far i need to wait for dreambox update. I just connect to xtreme editor link to download my line from source. Maybe it would be better load line locally, but i don't think so that could be a reason. Overall that is not a big problem, but just ennoying.
MikeT
14
#4
I have a Dreambox 900 UHD and i use openatv. For me is that the best Software for dreambox. I have no problem with it.
eltonbregu
I've been using IPTV on both, but also on VTI for quite a long time.
I do not see any difference.
More than the image, more important is the decoder and above all the server
elackner
Reseller: visions4
54
Switzerland
viptv.top
Reseller Username
visions4
#7
But VTI is for VU+ Boxes
I use this image on my VU+ Ultimo and freeze all the time. Since i change to OpenPLi works perfect.
A clients Dreambox 800 with Nemesis -> bad, i change to OpenPli and works perfect - same Box, same Internet, same Line
an other Dreambox 820 with NewNigma2 -> very bad, i change to OpenATV and works without any freezing - same Box, same Inernet ...
and so on ... i set-up a lot of Enigma Boxes and my expirience say, hands away from VTI, Black Hole, Newnigma for IPTV
Likes: spec119
eltonbregu
Yes VTI is only for VU+ boxes.
My Vu+ sole SE works perfect on IPTV with VTI 9, 11 or 13 image version, Rapid included.
The rest is personal preference
spec119
21
Reseller Username
spec119
#9
I agree just converted over from OpenVIX to ATV works a treat
Likes: elackner
