Hi all,
IPTV has been working fine on a dreambox until a few days ago. The provider said that they’re now using a new method of streaming which will make some apps no longer functional on particular devices. It was mentioned that if I wanted to install XstreamTV on the dreambox, which I have done it will work for IPTV.
Now how IPTV was previously seemed to be more user friendly, with the ability to record, timeshift and a proper clear EPG. What the provider said was if I could change the IPTV player engine to OE16 then it would continue to work as it did previously.
Is this something that can be done fairly easy on a Dreambox running Enigma ?
