Help
Rockred
I hope someone can help with this problem. My Mag 254 which is working fine viewing normal TV channels, I try to view ifollow, which is a UK based channel, I get the message on the screen saying that You cannot be logged into two streams at the same time or words to that effect. I'm connected through im informir I have unplugged all the cables on the Mag box, then reconnected them but still the same.
Many thanks.
Similar threads
  • Contains 1 staff post(s)
Replies
Views
2K
