IPTV not working with VPNs
Terry Bell
My IPTv is not working with a VPN. The 2 VPNs I have used are Nord VPN and OpenVPN . When run the IPTV without a VPN is works fine but don't want to risk it for any period of time.
It happens both on my phone and my android TV box so pretty sure it must be the VPN.
Any help on this would be greatly appreciated.
Terry
Reactions: vitshinzo
vitshinzo
215
404
www.iptvluxury.com
vitshinzo
Hello dear member,
To make your subscription line working through vpn's you need Fristly to remove [force countries] option from your line on dashboard.
Terry Bell
Thanks Vitshinzo for your prompt reply. How do I remove Force Country Option from my Dashboard? All the countries are currently unticked. Is that correct?
vitshinzo
215
404
www.iptvluxury.com
vitshinzo
Go to dashboard > manage lines > action > press force country [frist line]
Then make sure there is no selected country so you can use vpn
For your case it's OK just check your pm inbox
