Iptv with a Fritzbox 7590 working better??
Fiet
Hi, i dealing with lot of problems but the M3u is good lot of Pepole using it without problem but i have freezer and Buffer all the time i try DNS change but didn't working maybe the hardware is the problem. I want to try a Fritzbox router is that the main problem here?
1,047
2,016
www.simpleiptv.net
Fritz Box isn't bad but if you think about a new router, better watch out for routers with integrated VPN CLIENT.
And try VPN, that most likely solve the issues.
Fiet
Hi, i try VPN but most Freeware and that's not Helping!
The Fritzbox i will buy us the 7590 Version is that with VPN Client that Model?
