MAG 351 blocking from Infomir any help ??
linlin
Hope someone can help me. I have a new Mag 251 Image 2.20.03-351 and since days the box is blocked from infomir. The problem is known. I have made a factory rest. This does not help ! An old software version I can not find for the Mag 251...I think the box is to new...Any solution for this problem ? Is there a new portal? If yes how is the address ? Hope someone can fix the problem !! Thank you and greetings
Reactions: Pietro Pizzi
sounds stupid but best way is to get another box like formuler, xiaomi etc. as MAG are just bringing issues... not really cool
I have to say the Mag 251 is a very good box and before it was blocked by infomir, the box has a very good function !!!
yes and you exactly wrote the problem. it was blocked by infomir. so it will not help how it was before as now and for the future MAG is not a good option.
