Manual installation (Smart IPTV app) for LG 2021
Gaby
22
75
37
Hello everybody
I have in a previous post asked "Which iptv app works for LG"
Got some answers and tried a few:
netiptv (doesnt work and its a scam)
duplex iptv (doesnt seem to work just loads and loads).
If you check on youtube there are installation guides for the Smart IPTV app and how to install it manually with a USB stick
on brand new Samsung televisions.
I have searched and searched but cant find anything simillar for LG televisions.
Cant even find an iptv app that works properly on the official LG app-hub.
It doesnt even have to be free, as long as it works!
1,045
2,014
Hello everybody
On LG tv you should be able to find SMART IPTV App. If you don't, then change country settings of your lg tv to another country, like uk or germany, probably a factory reset is necessary and choose then another country. But try to change country settings first and once changed, search again for smart iptv app.
