Need a IPTV player for MacOS
crocdeine
Hello, i need to find the best (and free) iptv player with a good ui, as we know, there are a lot of app and the good ones are paid on appstore, if someone knows a good app with a lot of features for macos (maybe an opensource project), i would be really helpful !
Try out Flex IPTV Lite (trial run . . free and PRO version is small contribution if you like it), Playberry or StartUp Show. All of these work with M3U files but particular like StartUp Show because my IPTV provider has specifically merged its functionality with this application for ease of use right out of the box; however, on my "obsolete" iPad, I use Flex IPTV because I can no longer update StartUp Show due to the new minimum system requirements.
Playberry and StartUp Show are very similar and I would say . . . "sister" applications and only the exterior "shell" is different. If you don't like the purple/dark mode interface of Playberry then try StartUp Show.
