problem with IPTV smarters pro and vpn
diabolik26
Good morning
I have recently been using IPTV smarters pro on my TCL TV. I am very happy with it but I noticed a problem.
I cannot import my VPN certificate (AirVPN). It doesn't appear when I have to select it. However, it is in .OVPN format. For the moment to overcome this problem I manually launch my VPN when I start my TV: not great!
Do you have an idea ?
Thank you so much
Yes I found the solution.
You have to go to the IPTV smarters pro settings and click on “switch device mod”, put yourself in mobile mode.
From there you can import the certificates. And then you have to go back to TV mode and that’s it!
Otherwise there is also the solution of installing the Open VPN for Android app and setting it so that it launches when the TV starts.
Reactions: Hectorious
