Problem with telia router
Pimpelkungen
I have a tvip 605, when its connected to router i can not reach the portal, but when i put the "wan" cable directly to the box its works fine. The ting is i would like to use the router because of all other things that is connected to it.
Is there any ports or something i should Open?
I have turned off firewall
Hope you have some ideas
Lagal
Fast response and free support - paypal,btc&swish
Feb 5, 2017
48
sweden
smurferina
Buy a new router and dont use telias router at all
