Question about more than one connection
DSlater
If you buy 2 or 3 (or more) connections, is that all on the same line? Or do you get more than one line (2 or more IDs and Passwords)? Basically 2 or more connections would allow you to record, and watch another channel or watch IPTV on more than one device, right? I do not see where you can buy more than one connection, but looks like you can buy another new account with new ID and password. Maybe the reseller has to set more than one connection up for you and it isn't an option in the dashboard???
