Smart iptv and samsung
medinmars
I'm completely lost....I've got a samsung 49NU8000 and i cannot find on the app store smart iptv.
I tried to install with an usb key like the process on siptv but my tv doesn't find the program. The tmg file is not recognized by my tv.
How can i do ? please help me ... i don't like to use smart stb.
1,047
2,016
www.simpleiptv.net
Hi @medinmars,
did you put the files/folder of siptv website into the root of the usb stick ?
TIZEN:
Make sure the userwidget directory is located in the root of your USB drive. The application will appear on My Apps screen among other apps.
non-TIZEN:
The SmartIPTV directory should be located in the root of your USB drive. The application will appear on a Samsung Apps screen among other apps.
My suggestion: If you don't know if your Samsung Smart TV is tizen or not, put both folders in the root of your USB stick.
