Here are settings for all common Smart TVs to work well with Kodi, this should fix the stutter or glitch every few seconds most of you will notice especially with motion movement and 24p Movies.
This is sometimes caused by your TV settings and has been tested on Samsung TVs BUT should work the same on most smart TVs.
Once you turn off the artificial Motion settings on your TV in most cases you should notice better playback of your movies in Kodi.
For Samsung goto:
Press the MENU button on your remote to display the menu. Press the ENTER button to select “Picture” and turn off auto motion plus. This has worked wonders for those having slight glitch or stutter during motion scenes.
For other TVs the setting is called:
Panasonic TVs = Motion Picture Settings
LG TVs = TruMotion
Sony = MotionFlow
Sharp = AquoMotion
Toshiba = ClearScan
This may not solve all issues but it is known to help in a lot of cases! hopefully, this helps for some of you.
For Samsung goto:
LG TVs = TruMotion
Sony = MotionFlow
Sharp = AquoMotion
Toshiba = ClearScan
