200 credits minimum?
tdljay
On the reseller dashboard it says the minimum to purchase credits is 200 when the actual number that allows me to proceed is 500!
I would like to try the system before committing myself to buying credits.
Why is it telling me 200 when the only number that allows me to proceed is 500?
please read more about reseller: https://iptv.community/threads/q-a-how-to-be-a-reseller.520/
If u want a Free Trial With Full Dashboard Options than check here for more info: https://iptv.community/threads/iptv-trial.8337
tdljay
Yes so you screwed up on the dashboard stating the minimum is 200 credits.
Only the first time the minimum balance for a new reseller is 500 euros, every further recharge is than minimum 200€.
WizeTV
Verified Reseller
42
17
WizeTV
You're probably the first reseller to misunderstand the system, give it a thought...
tdljay
Yes because you have so many actual tutorials that explain a dashboard you are thrown into.
Bourbon
Bourbon
The minimum is 200 and maximum is 50.000 as stated. But before you even go to the dashboard, you should read the post "How to be a reseller". That is step no 1 before you proceed to the dashboard. If you check that post out it is written: "The minimum credit for being a reseller is 500 euros. "
7,031
Just want to make it clear. For the 1st time, everyone needs to buy 500 credits without any discussion and bargaining.
Reactions: sypher
