Best Android box ?(Low Cost with 2Gb Ram)
Wonak
20
I'm thinking of buying a android box, what do you guys think about this one?
"X96 Amlogic S905X Quad Core 2G/16G Android 6.0 Marshmallow Wifi HDMI 4K Kodi TV Box Android Mini PC
https://banggood.app.link/VCqWIvyNyy"
Slow wifi and net also but for that money is very good.
Okey! This ones seemes alot better, and obviously cost a bit more.
"T95z Plus Amlogic S912 Octa-core 2G RAM 16G ROM TV Box
https://banggood.app.link/aiWIH17Myy"
Anyone tryed this?
harryporter
184
45
harryportir
Anyone tryed this?
Yes this one is bestseller, i would go for this one and it has gigabit ethernet :)
Here is discounted price http://www.gearbest.com/tv-box-mini-pc/pp_443590.html?wid=21
Wonak
20
Anyone tryed this?
Just ordered that one! Now I just have to wait .
Thanks for the link!
Cuvillier
Active Member
Feb 19, 2016
327
351
France, FRA
cuvillier
Anyone tryed this?
As there are products with low prices, I don't think that they have regular updates on ota
machovari
I want to buying an android box and I did a lot of research and come across this one, supports OTA http://www.gearbest.com/tv-box-mini-pc/pp_493137.html
And one more question, because I am newbie, when I provide my MAC address for Rapid IPTV subscription, do I give MAC address from my Android tv box or my Smart tv, because I would watch it with Kodi or Perfect Player?
Thanks in advance
Caffetin
30
Caffetin
Thanks in advance
You dont need to provide mac adress if you itend to use your android box for IPTV. You only need to load m3u list either directly from rapid server or localy after you download it.
Wonak
20
machovari
Thanks in advance
Thank you Caffetin for your response,
any words about Android box I mentioned http://www.gearbest.com/tv-box-mini-pc/pp_493137.html
TKore
I have the Beelink GT1 (also s912) and I am very happy with that one. There were some issues in the beginning, but they are fixed in the latest firmwares (also OTA). Could also be worth concidering. It is a really decent build quality (especially for the price) and it doesn't look as outrageous as the Sunvell T95Z. The remote is flimsy though, and could/should be a little bit better.
http://www.gearbest.com/tv-box-mini-pc/pp_416057.html
Reactions: harryporter
vpstv
New Zealand
vpstv
I buy these boxes and sell them with my custom kodi build with intergrated Prefect Payer as I find it the most stable and responsive iptv player on Android. You do have to get 10pcs in order to get them for cheap but the price of one is still worth the product imo.
https://xlintek.en.alibaba.com/prod....html?spm=a2700.7803228.1998738836.184.KxZf0J
Runs Perfect Player smooth as well with epg loaded. (using .hls output)
Rather than Kodi I would recommend SPMC.
Hit me up for more kodi related stuff :sunglasses:
harryporter
184
45
harryportir
How you have managed epg in Perfect Player?
snoopp
12
snoopp17
yes this morning it was stillworking, but i think its problem with my box i tried other one and it work fine
Ryv
I'm thinking of buying an android box, what do you guys think about this one?
This box has a terrible cooling solution, thermal pad that leads the heat to a big flat metal plate, the box is small and not well ventilated.
Hardware acceleration is a problem with amlogic and kodi, making kodi crash frequently. The problem should be in android.
But I accidently stumpled across LibreElec for S905/S905X boxes and finally got rid of android, and got a more stable box with hardware acceleration working stable.
vpstv
New Zealand
vpstv
About 2 days and then you need to Update/Refresh Prefect Player or just turn it off and on again. Problem on your side?
harryporter
184
45
harryportir
Yes i had a problem resolved by ading custom User Agent line like this one:
Mozilla/5.0 (compatible; MSIE 10.0; Windows NT 6.2; Trident/6.0)
Now server thinks that im connecting from windows and everything works well !!
Reactions: vpstv
vpstv
New Zealand
vpstv
Dude, now thinking about it..EPG's do play up at times..will adding this line fix it? I'l give it a try, thanks.
