AtomTnt
12
nope..
"This attachment cannot be shown at this time. Please try back later" (when i click on it)
AtomTnt
12
thks goxa, but i do use notepad++ and the default is set to UTF-8.
It seems that the convert to TXT to edit and "Save As" back to M3U does not make it a m3u file.
In the process of trying to get Harryporter surgestion to work.
Seems i will have to edit straight as a m3u.
By the way i have been seeing some m3u list web editors floating around the forum. Dont these exopes your Username and password to other people?
AtomTnt
12
Hi all,
Ok update..
Harry ....nogo same error.
I have the latest vlc.
I upgraded to net framework to 4.6 (4.0, 3.0 and 2.0 were also there)
But seeing this error only happens when i try to test a channel in the app, I will still try and edit list and try in PP.
Also harry...is there a way to select more than one channel at a time to delete..lol..like pulling teeth.
Thanks all.
goxa
14
CH
xtream-editor.com
goxa
Of course not!!!
Your username and password are stored encrypted
drob01
Hi!
I use Perfect player on my mxq pro android box and all is working fine. well almost....
I use Hardware mode for decoder which seems to work best for me.
However when I do that I don't get subtitles on movie channels like Cmore.
If I try another decoder i might get subtitles but loose audio. or the picture gets bad.
None of the decoders available in settings gives me good picture and audio and subtitles.
Has anyone else have this problem and knows of a solution?
Can i add another external decoder or something?
harryporter
184
45
harryportir
Hi!
Try with Smart iptv app.
Harry
tusktusk
I do what i do
77
66
Hi!
IPTV Extreme wowks well with subtitles. This player can add externa encoders and players also. There is also a pay version but its about 1€
SIP too but then you MUST pay 5.5€. Its no biggie but there is other options.
drob01
Thanks for the replies but I like perfect player and don't really want to change.
The wife has just finally learned to use this :D
