Frequently Asked Questions
Davor
Trusted Reseller
127
59
41
bloodyczech
than your username is in link and pass is in your mail,you need also to use dash for clients.If you forget pass than just go and renew it or writte to your reseller
7,031
Please contact your Reseller regarding this issue
Reactions: Jems
TVFanG
Hi! You know what, via a google search I joined this forum as I thought it was a "general" IPTV forum but in fact, am I correct in thinking that this forum is really for one particular IPTV provider only...namely "Rapid"?
Reactions: Jems
Jan 7, 2019
168
82
droelfmalbumst
don't have this issue. I press OK and the channel list appears where I was at last.
I only have to go "back" if I want to switch to another group
Alexsecret
Some initial questions:
- EPG Supported?
- Server Loction within EU or outside?
- VOD?
- Multiroom allowed?
- Pricelist?
- VPN Supported?
Thx
gefunk19
gefunk19
Hi i was wondering can someone help me , i am trying to list my pricing but a cant seem to get it to update , it will update currency and countries covered but not the actual pricing it keeps throwing me back to the start??
Sava
Usa
I have problems with smart pro iptv: the vod it’s working but the tv it’s not working.... I don’t understand,some one can help please
Baremic
When I use IPTV on my amazon Firestick and go to settings then IPTV Smarters Check for update I get a message stating that there is an update available. When I try to load it I get asked if I want to go to the Amazon Appstore the I get a message stating the the App has not been found. How do I get the update then?
1,026
1,994
You can install the new APK version, simply use the DOWNLOADER app and add the new source to download latest file.
Baremic
Thank you fore your feedback. I am new to this site and not by any means a computer expert. I don't understand what is the APK version? Where can I get it? What does add the new source to download latest file mean?
Sorry for being so thick.
1,026
1,994
If you need help with it, feel free to send me a PM and I'll try to guide you.
1,026
1,994
How you work it on Apple TV
jusuf00
Hello.
is it possible to insert epg for every channel separately from different sources if yes then how can i do it ?
Similar threads
  • Sticky
  • Contains 425 staff post(s)
Replies
3K
Views
349K
