Insert a line on Fotmuler (copy and paste)
BudSpencer312
15
Hi there. To insert a line in a player, like perfect player is almost a nightmare. I can't find a way to use copy and paste tools so I have to write it manually which is tottaly annoying because it is so long! Isn't there a simple way to use copy and paste tools? SO we can copy all the path and put it directly on perfect player?
you could use a shortener like bitly.com or send the playlist link to your email address open the mail at your android box, copy-paste tadaaaa
try as well some other apps like duplex play, or..... much more modern than perfect player
Reactions: BudSpencer312
BudSpencer312
15
Thanks. I'll try the shortner. No good trying to send it to email. Can't still copy the link inside the email... When I select the text there is no pop up link or button to make copy and paste...
trapex
312
466
EU
www.NEW-WEBSITE-COMING-SOON.com
trapex
Mate, just wonder: why you use 3rd party apps when you have formuler ? Use Mytvonline app and use stalker... Only portal name & url needed
But to answer your question: you should be able to use Air Sync Remote-Z app which is free avialbe on on android phones:
Use your Android phone or tablet as a wireless RCU for your Formuler STB. Easily navigate content and play games on your Formuler Z-series device with the built-in touchpad, gamepad, and air mouse controls. Use Air Sync Remote to quickly enter text by using the touchscreen keyboard.
https://play.google.com/store/apps/details?id=com.aloys.formuler.airsyncremote&hl=de_CH&gl=US
@Nonid unfortunately shortener service has always additional risk of malfunction. Sometimes they do not work permissibly.
BudSpencer312
15
I mostly is mytvonline2. I use others as plane B. Sometimes does not work.
