IPTV Community
Administrator
Jun 3, 2015
537
1,652
214
iptv.community
This thread is dedicated to technical question and installation tutorials regarding MAG 245/322.
Feel free to submit your questions and receive technical support from other community members.
VeeBee
Hi, I have a solution to watch Rapid IPTV with a playlist on MAG via Smart IPTV.
Through this I have also a running EPG automaticlly.
First, you have to setup the portal at your MAG device ( 250/254 should work, others you have to check by yourselve)
see this: http://sip******* WARNING FRAUD **DON'T BUY** PLEASE REPORT TO ADMIN *******/howto/mag/
Download the playlist from here:
http://rapidiptv.com/threads/m3u8-list-with-epg-and-logos.1005/
Replace your username and password in the .m3u file
Then upload it to Smart IPTV here ( you need you device MAC address, you can find it in the setup of your device):
http://sip******* WARNING FRAUD **DON'T BUY** PLEASE REPORT TO ADMIN *******/mylist/
You can try Smart IPTV for 7 days, afterwards you have to activate it here:
http://sip******* WARNING FRAUD **DON'T BUY** PLEASE REPORT TO ADMIN *******/activation/
You can regroup the channels manually also you can sort the channels manually in the m3u file. Copy & Paste work ;-)
Enjoy.
VeeBee
squeaky
SqueakyIPTV
looking forward to that. it would make the iptv service almost perfect. do you have an estimated time you plan this? 1 month, 6 months, next year?
thank you for an update
sheki
sheki
about 2 Days i have a Problem on MAG254 with Youtube, when i start Youtube the MAG is Freezing and only a Hard Restart helps, i got only a Red Screen from Youtube 1.5.1 and nothing works!!!
Did somebody else have this Problem with MAG254?
Thanx
Regards Sheki
Cuvillier
Active Member
Feb 19, 2016
327
351
France, FRA
cuvillier
Thanx
Regards Sheki
Have you update mag before have this problem ?
Firat
Thanx
Regards Sheki
No, I have the software on it r14
Cuvillier
Active Member
Feb 19, 2016
327
351
France, FRA
cuvillier
Thanx
Regards Sheki
Test in stb emulator app if you have same problem
Cuvillier
Active Member
Feb 19, 2016
327
351
France, FRA
cuvillier
