leo nilsson
leo nilsson
i have HDMI event reaction in Enebled but without changes (dont help)
leo nilsson
leo nilsson
have any better solution to fix the settings om mag 250, to not pull it from the power to start it,
I have done the
(turn CEC of
HDMI change to active
put Sleep screen on NO or never)
But without help !
Viper01
Hello everybody, i have succesfully flashed my dead mag250 back to life. I used a jtag to programm the bootloader back to flash
regards Triton
Hi mate.. I have a Mag 250 which is bricked. I tried ging through the PDF but seems too complicated for me. Would it be possible if I sent you the chip with the serial and mac address for you to unbrick it for me. I don't mind paying for the postage and a small fee for thta.
Please advise.
Viper01
Hi mate.. I have a Mag 250 which is bricked. I tried going through the PDF but seems too complicated for me. Would it be possible if I sent you the chip with the serial and mac address for you to unbrick it for me. I don't mind paying for the postage and a small fee for that.
I
checked my PCB board and it is V4.
leo nilsson
leo nilsson
hello agein,
Since i changed the settings , every time ehen i shut the tv , the mag box can olso be locked end can not be startet with remote controll without pulling the power cable.
Have enibody same suggestion what should i change in the settings please ?
sang
Hi everybody,
Does anyone have the latest firmware for mag250 clone?
thanks you
Ally Zaman
I need some advice. Mine was working fine but suddenly it started giving error “ensure that jtagpointout is specified correctly”
can somebody please help.
Ally Zaman
Does the programmer work on win 10 ? Can’t seem to find device , no drivers , is it only XP
You can install using compatibility mode and can install the drivers by disabling drivers signatures enforcement. Drivers are in STM folder. Mostly on C drive
Burgi
Hello
My shot always breaks off after about 30 seconds! Then the ad:
PVR Error- End of Stream.
What can I do?
Find no information ...
thanks for any help
Hello
What can I do?
thanks for any help
sorry to tell you, but this feature is not available mean recordiing!
Reactions: Ivangallego
Keyn
hi to all, I followed your guide successfully and I got unlocked.
I would like to thank Triton in particular for this.
I have upgraded to version 2.18 r19 and run for less than 24 hours.
The device has returned to Bricked mode.
I'm running more tests but it will take some time.
Has anyone solved for this problem?
gary b
hello
does anyone have previous mag250 firmware versions? the ,atest one is 218 r22 I am looking for earlier versions - cannot find them in informir siter17.
much appreciated
Joaquin Blume
Ebay
Hi there! What kind of provider are you using? I am looking for Danish tv in Spain can suggest some one?
Camdtv
i cant install "st micro connect lite driver" :(, it says cant install DPInst.exe and that i need the 64bit version but cant find that :( ?
Any1 else had this ?
Mikeios
29
@ Camdtv it looks like you omitted a zero in the command line. It should read STMCLT1000A whereas you seem to have the following in yours STMCLT100A
Mike.
DP1
Greetings all,
Just one question. Can this method also be used to flash a 254 which has been locked by the provider?
Many Thanks.
Camdtv
Yeei got past a few steps :D, BUT now my terminal wont recive info :( and i done settings and its com 8 in device manager .
Any ideas wht i can do ?
Nishant15060
Can I get some guidance
When I run MProg 3.5 then choose scan I get
Number of blank devices = 0
Number of Programmable Devices = 1
which is the otherway around to your screen.
Can you explain what have I done wrong as up to this point I have followed all your instructions
I have FT2232H-56Q running on an old XP Tower
Asif
Did you try with Mprog 3.5 any luck to retrive your mag box. Can you please explain how to run brick fixx firmwere...
