Rach_Agius
Malta
Hi everyone,
I'm using Perfect Player on a Q+ smart tv box (Android 9.0) and every time we're watching live TV, the app is closing down and going back to the home screen after 5 to 10 mins. This doesn't happen when we're watching movies though. Any thoughts on what is going on and how (if) it can be fixed?
Scasuro
14
Hey guys
I dont know why but I have an anoying problem. After switching channels I have a delay for about 5-10 seconds...2 weeks ago this problem doesnt exist...I tried a different player like GSE or Kodi but still same issue. Try it at another place (parents house) and still same issue
Sense
629
450
www.sensus-tv.com
Sense
Hey guys
This is general for any app atm.. Not an issue on your side. Just hang tight and it wil get resolved ;)
ChrisNeroKing
I’m new to Android TV boxes, IPTV, Perfect Player & all. I have no idea how any of it truly works.
Why do all of my channels work just fine except for this one channel that I really want to watch. It buffers and then shows the red circle and doesn’t play. Can someone help?
1,023
1,991
There are still some single channels which needs to be fixed but technical team is working on it and I expect to get everything fixed soon...
Mik
Hi I am using Perfect player, but cannot get the EPG to work at all. I did paste that link correctly, what am i doing wrong?
curtis87
Hello
I get the m3u url from my iptv provider i do the settings but when I update the channels it s written "nothing updates"
What s wrong?
Ramon Chircop
Trusted
37
ilking
Hello
What s wrong?
Check that you have copied properly. Common mistakes are "O" and "0", "I" (capital i) and "l" (small L).
curtis87
I wrote the Url down properly i checked it, i tried to change the Decoder from Auto to Hardware, the same issue, still displaying no channels.
Ramon Chircop
Trusted
37
ilking
If it's not updating it's a url problem or an Internet problem. Are you seeing a list with channel names? Try the url on vlc.
curtis87
I don t know how to add the m3u url on vlc so i tried with lxtream still doesn t work, i get an error when adding the URL, "login failed", it s strange because it was working yesterday
PeterLang
46
17
Germany
HI ... here a strange behavior with Perfect Player an EPG ... i have added the EPG link with usernam and password... this works fine for 2 or 3 days then the EPG finally disappear on Perfect Player... so i deleted your EPG link, stored went back and add it again ... the EPG is refreshing back. It seems that after server refresh the Perfect Player can not handle the automated EPG download from the server.
Perfect Player does not refresh depply, he refreshs only the channels but not the EPG. Do you know anything about this issue? Is there any setting to to in Perfect Player?
You can force EPG downloading by means of using ‘Down‘ key (instead of ‘Ok‘) when the cursor is on the ‘Update‘ button.
Open Main Menu
go to the update button
Now instead of clicking Ok‘ on the remote control
hit the Down key at the remote control... to force epg download
Reactions: PeterLang
Davinci1979
I have an issue with channels back option, when I open channel A and then channel B, If I will come back to channel A its almost every time not working, only after 1 min its working. I used both M3u with option and without, and ts, not changing anything.
