tusktusk
I do what i do
77
66
Thanks for the replies but I like perfect player and don't really want to change.
The wife has just finally learned to use this :D
Hi, then you have to wait untill Perfect player add the suport for DVB subtitles.
But i can recomend IPTV extreme when its all setup its very easy to navigate and use.
Just install it one rainy day and see what you like..
pit13
Extreme iptv is quite good, many useful settings, like app can load up at start of android box,
BTW I can`t find a way to edit remote control settings in extreme iptv , do you know Lads can this be done?
PeterLang
46
17
Germany
I have the fire box and PP as well and it works fine except 2 movies: Star Wars IV and V .. i do not get any audio .. is it the same on your box? Can you check it? You will find both movies in VOD
harryporter
184
45
harryportir
Those 2 movies have ac3 audio and thats why they dont work,
Harry
HaXoL
Hi there,
Is anyone who knows how I can record channels with Perfect Player or different method (other app)??
Rambler
Hi All,
I'm new to this IPTV thing.
I signed up for streamcenter and got perfect player working perfectly for 2 days (no pun intended). Super happy with my set up. I run perfect player on my MXQ pro mini android box running marshmellow.
2 days later, I turned it on and the EPG was not showing. I did some research - cleared cache, fresh install, rebooted, etc. Nothing worked. Also, the weird thing is that the settings menu won't open, it just says please wait and then the message disappears and goes back to the empty EPG screen.
I know the playlist and EPG URL are all working because I'm using GSE smart IPTV app for now. But I don't like the Smart IPTV interface.
Any suggestions? I couldn't find any info on this issue and now I'm desperate for help.
RA10Bayer
is it possible to sort channels in the favourites?
For example i have 100 Channels in favourites and now i want to put a channel on the position 5.
If not, is there an other app with such a configuration?
Rusax
Let me show you the world
Feb 4, 2017
576
743
www.rusax.nl
Rusmir
next time try google first its vaster the first link wil show you a answer
Settings->Advanced->Groups management mode
place the channel you want i an new or exsiting group.
and than press on show favorites, it wil show you only the favorites
pista18
Croatia
When you get message "please wait" that means playlist and epg are being downloaded, you can see progress grey line on screen (upper right corner). At that time you can not enter into settings so give it a little time for download to finish. Then you will get epg.
...and if you already didnt, set epg in settings to download once a day.
Rambler
The "please wait" messages dissappears and nothing happens afterwards. I believe that the EPG URL I'm using is no longer active for stream center. That's why it doesn't do anything cuz it keeps trying to update.
This is the EPG URL I'm using. Is this what everyone is using?
http://epg.streamcenter.tv/p2.xml.gz
tusktusk
I do what i do
77
66
Android version 1.4.3 beta3
It came out 20 sept. I have been using it for a bit and it works like a charms.
I think this will be final version before a final release.
Change log v1.4.3b3:
Fixes
Its just minor changes from b2.
Change log v1.4.3b5:
Added support of XMLTV EPG packed with XZ
Added support of EPG URL with authentication (http://user:pass@url)
Added archive support for “ottclub” provider
Added catchup tags support
Request external storage permissions when needed
Fixes
Change log v1.4.3b6:
Added ‘Xtream-Codes’ archive/catchup support
Greek localization improved
Small GUI fix
Have a good day!
Sparky56
I am looking at the settings on perfect player and i can see that you can have more than one playlist. How dow do you swap between playlist 1 and playlist 2?
Any ideas? thanks
agax
I have made a full reset of the FireStick already and install the Perfect Player again from Amazon.
The new FireStick have last firmware V5.2.6.0.
When i try to start the Perfect Player is shows short the start logo and goes back to the home start side of the Amazon FireStick.
Any idea. It have work already for over one month.
Agax
RyggLukt
19
Fixes
Download Apk
Reactions: tusktusk
tony76
Fixes
Download Apk
Nice, I have been using Perfect Player for a while, and its great, will you add recording and catch up support in the future?
tusktusk
I do what i do
77
66
New update: Beta 6
Small GUI fix
Se above for previous updates.
Reactions: RyggLukt
RyggLukt
19
Change log v1.4.3b7:
Added ‘Ezserver’ time-shift support
Show channel archive window by “Left” key long press for selected channel with archive
Fixed volume control on Android TV devices
Czech localization improved
Fixes
Download
Reactions: tusktusk
tusktusk
I do what i do
77
66
Hi guys the best app just got even better!
http://niklabs.com/android-version-1-4-3-released/
Change log v1.4.3:
Added DVB subtitles support (HW+)
Saving selected subtitles track (HW, SW, HW+)
Improved subtitles rendering
Added archive/catchup tags support
Added ‘Xtream-Codes’ archive support
Show channel archive window by Left key long press for selected channel with archive
Switching next/previous channel relatively to the currently playing channel
Ch+/Ch- keys acts as PageUp/PageDown when media list is showing
Added “description” M3U tag support for VOD playlists
Added Macedonian localization
Improved Greek and Czech localizations
Other fixes and improvements
Have a good day!
Reactions: RyggLukt and Sense
YuSuF79
Germany
Dortmund
You do not get to choose which playlist you want to watch, if i remember correctly, you get all channels listed.
