Siptv smart iptv LG issue
zelise
Not sure if anything has changed recently, though siptv app and smart iptv on LG no longer seem to load the rapid playlist. Different vpn’s tried.
Smart-stb on LG works, but i prefer smart iptv.
Has siptv changed the accepted format of the playlist url (tried all) or is rapid no longer supported via the LG smart iptv app with siptv load?
1,023
1,990
@zelise try to remove power cable from LG tv to clear cache and then try again. If it doesn't help, go to dashboard and reduce the bouquet list to a minimum, once done, remove power cable again and it should load, cause most smart tvs having limited cache/memory.
