Does it matter
yellow
Good day everyone hopes everyone is doing well today.. I was wondering does the type of android box affects the performance of a IPTV subscription.. Like installing the app directly to a smart tv or is it better to put it on a fire stick or android box. what are the benifits
yellow
Or does it all boils down to your internet
CJ2015
25
15
In my opinion I would definitely use a streaming device android based. I use Nvidia shield and they work great. Yes your internet affects things as well but android devices do perform better than using your smart TV.
1,025
1,991
Most SMART TV’s having limited cache/memory.
If your Device has limited cache or memory (e.g SMART TV), then reduce nearly all Country Groups from the Bouquet List in order to reduce the m3u file size to a minimum. Once the Bouquet List has been reduced to a minimum, you should be able to reload the http m3u link Playlist on your device even you have limited cache or memory.
If you want to load full m3u even m3u size is big, then better use premium hardware like android box etc. where you enjoy flexibility and on top of that you can install nearly all apps on it e.g. vpn ;)
