GSE Smart IPTV Pro - Not working right anymore
ChrisKh
24
Hi guys!
The reseller i bought my iptv from had an update that just finished. But before it finished, like 4weeks before, i noticed that the channels I stream on the "GSE Smart IPTV Pro" app are in disarray, like they're not in the same right order anymore. and the logo for each channel are no longer displayed. And the EPG doesn't work either.
Has this happened to anyone?
You know what to do?
uriX
Hi guys!
Only the Xtream code API does not work. Otherwise, m3u is working as usual.
Reactions: ChrisKh
