A solution for the problem had been nice... Seems like server problemsI can also confirm that it has been horrible, especially this weekend and VPN or not. Tried different internet connections also.
iptvhelpcenter.com
Thanks. Will try this.You need to change DNS Server settings... especially in Sweden, the ISP set throttling under dns servers!
Login to your Router menu and change the DNS from automatic to manual:
For IPv4:
9.9.9.10
149.112.112.10
For IPv6:
2620:fe::10
2620:fe::fe:10
sometimes: if a hostname must be added, you can use cloudflare: 1dot1dot1dot1.cloudflare-dns.com
How to change DNS on different IPTV devices? | IPTV Help Center
In this tutorial, we are going to show you how to change the DNS on your IPTV devices such as MAG, different Smart TV's, Android and iOS. Changing your DNS settings is usually mentioned as one of the simplest ways to optimize your internet speed and solve many issues you might encounter while...iptvhelpcenter.com
For IPv4:
9.9.9.10
149.112.112.10
For IPv6:
2620:fe::10
2620:fe::fe:10
