Help
340rag
The latest update for Smarters Pro has eliminated the EYE that shows the password when you edit a user anyone know why and if it will return on next update,I tried to add the previous version on my shield to no Avail I do not want to completely remove and re-install because that will lose all my users,Thank You Kindly
PaTech
Subscriptions, Free Trials, Support
23
DC
PaTech
Don't know what version you have on the Shield but my Smarters Pro on Android phone still have the EYE icon version 2.1.1
426rag
I has the eye when you add a user but once you add the user hold down your remote to go to edit and that is where they took the eye away...Boo Hoo
Flipper
I have version 2.1.2 no EYE now looks like 2 heads in top right corner for adding or editing a playlist.
