I Premium i9 tv box
Inuendo
19
24
hello everybody, i bought a I premium i9 tv box. I would like to know if someone has a lot of experience with this tv box
Sense
629
451
www.sensus-tv.com
Sense
Hi there!
Welcome to the community.
Seems that the premium i9 tv box is based on Android wich means you can run alomost any Iptv app on it.
Is there anything specific you are wondering about ?
Inuendo
19
24
thanks for your reply. Today i got a trial from rapid tv.
only when i watch a movie( vod multisubs) i cannot use subs. maybe i have the wrong player?
Inuendo
19
24
i have, but some apps, like iptv smarters , but this app cannot be installed.
so its a matter of finding the right app
Inuendo
19
24
i use an internal movie player. I think the problem is like this. When using a Mag i can change also subtitles. Now i use an android box having also a mac address.
maybe i used the wrong internal player and i have to change it for another player from Google play. or i not use the mac address?
not sure whats the best because i never used m3u
Inuendo
19
24
i had a trial for 2 days from Rapid iptv.
i guess you are right, i downloaded the GSE and found on this forum a tutorial about GSE , so i will try it and instead of a mac adress i use m3u.
