C Chilibyte New Member Sep 22, 2019 3 2 3 Aug 15, 2020 #1 I’ve seen that IPTV Smarters is available in the US for Samsung Tizen TV’s. Is there any way to get the app loaded via USB like SIPTV? I don’t like the way SIPTV looks, I wan’t a full EPG showing next program etc, and pictures of the VOD’s.
ylliricon New Member Feb 11, 2021 3 0 1 Feb 11, 2021 #2 HI if by any chance you have found the download link for IPTV Smarters please do share it if you dont mind Thank you
Hectorious Official Verified & Trusted Reseller May 5, 2017 1,045 2,014 213 www.rapidiptv.live Feb 11, 2021 #3 On samsung smart tv you should try the DUPLEX app
C cerberus1846 New Member Mar 1, 2021 2 0 1 Mar 1, 2021 #4 I use QUZU and it seems to have what you're looking for!
ylliricon New Member Feb 11, 2021 3 0 1 Mar 3, 2021 #5 Hectorious said: On samsung smart tv you should try the DUPLEX app Click to expand... Thank you
Maliik New Member Oct 9, 2022 1 0 1 Oct 9, 2022 #6 If you want install the app on your Samsung device you should change your store country simply
