Merci beaucoup Cuvillier pour ta réponse instantanéeCheck :
I hope that RapidIPTV will be very shortly up and rapid as you
Avec plaisir.Merci beaucoup Cuvillier pour ta réponse instantanéeCheck :
I don't know if you use pro version, but in it you can create custom group and put your wanted vod in it.Hi,
i use the ******* WARNING FRAUD **DON'T BUY** PLEASE REPORT TO ADMIN ******* chanellist online on Kodi via Xtream-Editor. As you can edit your channellist as you like there i wanted to know whether its possible to make an extra channellist with only VOD movies and use that m3u in an extra menu in kodi. now i have them together with all channels in the "TV"menu. i want the VOD movies separate.
sorry for my bad english an thanks in advance.
There is playlist loader yes.Thank you for the fast reply.
i use the light version with 2 useable lists. I wanted to use one list for the TV menu and the VOD movies in the second list inside a separate menu in Kodi. my quetsion is about kodi whether there are some addons or a setting i can make to have that second list in another menu.
If he want 2 playlist custom, he can load them in the plugin playlist loader.Cuvillier seems not to understand your question , what you want is to have the possibilities for a seperated section for VOD's and also for Channels ...Thank you for the fast reply.
i will recommend to use Rapid IPTV addon ... for kodi
its because its down right nowHi,
I haven't been using my IPTV on Kodi for a month, and when I tried to use it again (Version 17.1), i get no channels loaded using the IPTV Simple Client. I haven't made any changes on the URL since the last time it was working (http://clientportal.link:8080/get.php?username......)
Is there anything I need to do? I habe noticed that the "Run" button on the Simple Client add-on is disabled/greyed.
With me on Samsung Smart TV it is not there yetIts back online again!
With me synonymous on samsung smart TV since hours offlineNot online neither on kodi or simple iptv
