MAG Portal URL Not Working
a-network
25
a-network.ca
support@a-network.ca
All My Clients Using MAG Devices are complains that the MAG Portal is not working, i have tried it myself and it says Error 404. I got the channels from rapid iptv
if you have a problem with Mag Device, then pls check the new unique portal URL from your dashboard,
you have to update your device with this new portal URL. If black screen resist,
then run the Diagnosis test within your dashboard and it should start working m8
(reload portal when done)
Incase of probs pls submit a ticket and provide information Mac address, Device name , IP address
