Dear All,
Seems MAG 322/351 blockage from Infomir in the new version of firmware
Please try this process:
- Factory reset the box
- Auto software update OFF (before connecting to the internet)
- DHCP update OFF (before connecting to the internet)
Just change in portal link letters mag to cdn. Thats the trick! Do you have noblock firmware for 351 model? Can you share with me?Hi.. My Mag351 is not loading properly on this system ... the loading bar fills out and instead of coming to the choice of portals is loads the media browser where all the icons are mixed... Nothing happens when pressing buttons on the remote. I can only go back to loading portals..
This is only happening when i try to start Rapid.. the box loads other systems no problem.
I´ve did a works reset.. started afresh put the info needed back into the box.. No change.
Changing the DNS.. changing the pasword.. updating my bouquet.. nothing has helped..
Anyone any idee´s???
Did you Fix this...?Hi.. My Mag351 is not loading properly on this system ... the loading bar fills out and instead of coming to the choice of portals is loads the media browser where all the icons are mixed... Nothing happens when pressing buttons on the remote. I can only go back to loading portals..
let me know if you have found a solution pleaseNO.. i´ve contacted the developer.. he´s working on a webpage but will get back tomorrow or Saturday
