Multiple connection in same home - which option to choose
chambrai
If I want to use TWO separate Mag devises in the same home at the same time, shall I choose the option 'Multiple Connection: 2' when extending the credits or make TWO SEPARATE lines, each with its own credits?
2 separate connections you need, as you can add only 1 mac address per Line,
Reactions: PocoLoco
chambrai
Thanks for your quick reply. One final question, so when I buy 2 seperate connections/lines, the fact the there will only be one IP address at home shouldn't create problems?
iptv365swe
✵VERIFIED & TRUSTED✵ ✉pm 24h trial/sub
Sweden and Norway
iptv365swe.xdns.pro
iptv365swe
text in dashbord:
Not possible to add multiple connection on MAG devices or add multiple MAG on the same line!
Current Connections2 Allowed Connections2....
Is it possible to run multi connection?
on 2 mag boxes if they have the same mac?
//iptv365swe
Scandix
34
Bandipandi
text in dashbord:
//iptv365swe
No Mag has the same Mac adress.
