Need Help
Christopher Latham
Hi guys, I have a smart tv (LG - old one) and I ha d an iptv package on there for years but 5 days ago it just stopped. Im not completely useless and tried other smart tv apps on there too and all would not connect. My friend friend brought over to my house an apple tv box which works at his home but when he plugged it into my tv with my wifi it - the GSE player said ”Unable to fetch” and he was a little unsure why it did not work. We used our telephones on the wifi with new apps and the tc worked (we were only connected to the wifi). I checked the list of internet providers that block IPTV in Sweden but mine is not in there. So the wifi works with our phones but not with the smart tv apps or functional apple tv. Please help?
vitshinzo
216
410
www.iptvluxury.com
vitshinzo
Hi, i would like suggest to reduce your playlist to minimum then try again , And before doing this Can you please Try with your Mobile data (hotspot to your Smart Device)
adwinafram
India
adwinafram
I would suggest you try another IPTV app on your Smart TV. Some of the best apps are -
  • TiviMate IPTV Player
  • Smart IPTV
  • IPTV Smarters Pro
  • OTTPlayer
Root025
iptvsmarter.tech
Hi, I would suggest you to change the DNS to Google (8.8.8.8) or Cloudflare (1.1.1.1) and disabling any firewalls on your router or you can try another application on your Smart TV as IPTV Smarters Pro, TiviMate and Kodi.
