Hi Guys,
I use on my Shield SmartIPTV App, works fine.
Sometimes i have problems with buffering. I use the MPEGTS Links..
Should I switch to HLS? Do not know if it has an influence
Hi Guys, I use on my Shield SmartIPTV App, works fine. Sometimes i have problems with buffering. I use the MPEGTS Links..
Hello Kobii,
Yes, you could try with HLS, to see if you got any improvements.
Information regarding MPEGTS/HLS - check out this thread.
A way for you to get the most out of your IPTV experience >> check out this thread.
Hope someone can help me.
I was just trying out the service with Perfect Player on my Nvidia Shield but I can't figure out how to browse across different groups.
When I use Perfect Player in the PC I just have to click left/right to move across the different groups. However, when I try to do the same on the Nvidia Shield, with the exact same configurations, the only list I have in the menu is the one where all channels are listed. Clicking left/right on the remote doesn't move me across the different groups.
Am I missing something?
Hope I was able to explain myself.
@asilvster92
Make sure that you have this set under " GUI " settings in Perfect Player
