Philips SIPTV Technical Questions
IPTV Community
Administrator
Jun 3, 2015
624
1,726
214
iptv.community
This section is related to technical issues and support questions regarding SIPTV App on Philips TV's.
Feel free to submit your questions in this section in order to get help from other community members.
harryporter
184
45
harryportir
Anyone knows how to get rapid channels on philips?
You can do it only if it is Android Philips tv
can you explain me hot to do it with philips android tv?
thanx
From Google play on your TV install SMART IPTV aplication. After that upload list via sip******* WARNING FRAUD **DON'T BUY** PLEASE REPORT TO ADMIN ******* to your TV. If you need more help let me know
Christopher Latham
Can I get/download Perfect player on 55 LED-TV Philips 55PUS8602/12 UHD Smart, I want to know if I can avoid a box without routing the tv
Jaha
110
Its on Android TV it seems? You should find the PerfectP on appstore then also SmartIPTV.
tremitech
vetvendosje
sweden
Vetvendosje
How can I install smartiptv in Philip's tv
It's not Android it's new series can any explain how install smartiptv apk
tremitech
vetvendosje
sweden
Vetvendosje
How can I install it do you have any tutorial pls
Need help I have Install ssiptv but is not working
revengeyo
When i load up rapid with Siptv, i only see one group.
Then i have to scroll trough 10.000 channels to reach my country..
Is it possible to separate groups?
uriX
If you didn't fix the problem. Contact me at PM and I will help you further
Reactions: revengeyo
revengeyo
I like Smart IPTV, but often when switching channels, the channel freezes, but audio continues.
Then i have to restart Smart IPTV. Now iam too scared to switch channels
uriX
Hi. Which device do you use?
Have you last update for your app?
Sense
629
451
www.sensus-tv.com
Sense
I tried all things, but image keep freezing fast after switch channels
I also have a Phlips Android TV and i can confirm that on the new update for siptv image is freezing from time to time even when you use HLS , Best advise atm is to use another app and maybe wait for a new update to come out :)
