As far as I know, this model runs with LINUX (Saphi) instead of Android. Not sure if you are able to install siptv on it.Hi!
I have a PHILIPS 70PUS6704/12 TV and i cant find the "smartiptv" app anywhere....?
Can somebody please help me, a step by step guide.
As i want to switch from my old LG tv to this new one...
Hi! I have PHILIPS The One 70PUS7304 and having issues with playing movies .mkv through Smart IPTV app. Just received the account so idk if its bouqet disabled or if its problems with this app.
Anyone knows?
TV say file cant be found or read
Thanks! Solved issue by installing VLC as external player. After search i found movies wasnt supportedsince your TV is based on Android i would recommend installaing a different app .. Like XCIPTV
that app wil handle .mkv
