Problem with Installation of Smart IPTV .tmg app on Samsung
Rinaes
Hello, I had to reset my Samsung Smart TV R Series and expectedly lost all my apps. I tried reinstalling the Smart IPTV app with the userwidget on my usb stick and I am getting this error message:
[User App] ._SmartIPTV.tmg, invalid app package for security check failed!
What can I do?
1,051
2,021
www.simpleiptv.net
What can I do?
put all files from tizen widged & orsay widget on your usb root folder.
plugin your usb stick to the tv, turn tv of and turn on again and you should see the app under my apps.
Alternatively you can try the DUPLEX app which is available in Samsungs App Store.
Reactions: Rinaes
Rinaes
I am using the userwidget. i am getting this error message ...is there maybe an updated version
reineken
A year later, any solutions to this problem around? I havent made much progress. Tried every way I could think of, but TV refuses to install.
